A
Anonymous
Guest
Blimey these questions are rolling in now.
My Sister in Law has had a survey come back on a house she put an offer in on.
One of the major items is damp.
You can see the house on the link.
It has 225mm solid brick walls with signs of bitumous damp proof course. There is high reading of damp to most of the rear rooms. It may be caused by the fact that some render has been applied to the lower part of the wall, and has in fact gone below the DPC.
I have searched the past posts to see if there are any links to extra reading on this, but have drawn a blank.
Can any give me any advice I can pass on to her?
Obviously a damp expert would solve the problem, but what sort of damp expert should I get in? The house next door seems to have had a damp problem, as it has the drilled and filled holes, which I'm sure has a proper name!!!!!!!
Anything else I should tell her to look at?
The electrics need doing, but we new that. Repointing in places is dodgy, so that needs removing and repointing again.
Cheers
Graham
Old house with damp!!!
Cheers
Graham
