Seanie_230
Hello All
last time i had a problem i posted about my joists under the back door.
http://www.periodproperty.co.uk/forum/viewtopic.php?f=1&t=13130
On Saturday i fixed joist with the pink lines and found out that the other joists with yellow lines are also rotten.
i found that the part of the joist that sits on teh wall is rotten and crumbling.
i used a bower beam to fix the first joist and they haev all been treated with boron for fungal and rotting.
i have some questions if you can help
Should i sister (side by side) some meter long joists and put them into the wall under the step and cut away the rotten bit that is current?
from what i can see the existing joists support the step so i assume i need to put somethign in there place like the new joist ends.
the joist on the right seesm to be supporting the step on the right hand side.
i read people saying make sure the new joists are wrapped ni damp proof course will this work?
should i bolt the joists together for strength
how far apart should the bolts be?
is there a washer i should use between the joists?
how should i support the joists while im working on them to make sure they end up level?
help anyone please its getting cold and i want to fix, insulate and put my floor back down..
cheers for reading
cheers for reading
