A
Anonymous
Guest
I have read with much interest the debate on rising damp and agree that it is a very rare occurence.
I live in a 1920s home with solid 9 inch walls. The property is located on the North Kent seafront and benefits from plenty of cold northerly winds.
About 15 years ago the former elderly owners were conned into having damp remedial work carried out at exorbitant expense. It appears that all they did was to hack off, DPC, sand cement then skim plus the addition of fake wooden panelling. Needless to say the topcoat skim plaster beneath (both internal and external walls) is crumbly, with salt deposits clearly shown on the render (see photo 1). Where it was papered, there was moisture under the paper.
They also had the house covered with a nasty plastic coating caller Weathertax or Weather coat which, I assume, has removed any chance of mositure leaving through the external walls. The plasic coating has been put on the chunky original pebbledash (quite common round here) and the exposed brick bottom half of the house.
Some ground floor joists will need replacing as the floor is quite 'spongy' as the airbricks had also been covered with earth/paving above internal floor level.
Anyhow, have now lowered external ground levels, uncovered airbricks and, through dehumidifier and heating the house has started to dry out.
I would be gratful for some guidance on the following:-
1. Any ideas how much of a problem the textured coating is?
2. Internally, is it best for me to hack off render back to brickwork and apply lime plaster to the lower half of the walls to allow it to breathe. If so, do I hack off and wait for a period to allow the walls to start to dry before plastering?
3. If I apply lime plaster, how does this restrict subsequent decoration (was planning to apply Fired Earth/Farrow & Ball matt emulsion).
4. In one room, the party wall, there is evidence of dampness upto 6 feet high. Next door have recently had DPC. Would this have effect of 'pushing' any present moisture into my house?
Needless to say, local 'specialist' company recommended chem DPC, sand cement & skim with waterproof additive for princely sum of £4200!!
Thank you in advance for your comments.
