timinder
- North Walsham, Norfolk
We're in the process of selling our house, and I have the buyers' mortgage surveyor coming tomorrow.
First, a bit of background, then my questions:
The cottage was built around 1850, extended a little in the 1980s and then a few years back we had the 1980s kitchen (which was awful!) re-built.
The previous owner had the following done: Concrete floors, cement plaster up to 1m internally, complete cement rendering on the outside, possibly chemical DPC (we found a guarantee certificate, but thankfully no ugly holes in the walls...). And also someone had painted up to about 1' high some black bituminous substance (it has mostly flaked off now though).
This caused us problems in one of the downstairs rooms with paint blistering off above the cement plaster, and externally with some bricks spalling.
Around 18 months ago we had the cement pointing replaced with lime, scraped off the internal modern emulsion and re-painted it with Earthborn clay paint (which is lovely to use).
For some reason best known only to himself, the builder also fitted a synthetic DPC material along the mortar line of the outer course of bricks. I can't see that this will do much, as the inner course is unaffected by this.
Since then we've had no issues with dampness at all, but just for fun I poked my moisture meter (used for checking wood for the fire) into the cement on the wall and it said that it was "damp". I know that it isn't, and it's just the conductive salts in the wall.
What's concerning me slightly is that the surveyor may come round and do the same thing, then recommend that a DPC is needed, which could possibly put off our buyers (a lovely couple, but first-time buyers and quite cautious), or induce the mortgage company to impose that it be done as a condition of lending.
I'll be there while the surveyor does his thing, so if I see him get his meter out, should I dash it from his hand and send him away with a flea in his ear (and a link to this website!) or say nothing? (or possibly something in between, like ask if he's qualified to inspect traditionally constructed buildings?)
My other question is that during the repointing work, we had a a fair few bricks replaced in the gable wall and subsequently a few thin (<1mm) cracks have developed around the ceilings on that side of the house. I'm comfortable with that as it seems entirely reasonable that a bit of settling would occur with the amount of work that was done, but again, should I try to pre-empt the surveyor, or keep schtum? (the cracks are no worse now than they were 12 months ago.)
My third question would be to ask if I'd used too many brackets in my text, but I think I know the answer to that!
