I have a listed building, 1840 circa, neoclassic revival, bought from a guy who recently rennovated it.
The conservation officer is well aware of th e "B&Q" coaving and fireplaces from the plaster shop down the road etc, and is cool about me removing them and replacing them with something more fitting.
I was wondering if anyone had advice on what to do with the interior walls. I have peeled back tiny bits of the plastic embossed wallpaper to reveal modern pink skim. And its not very well done and not flat - where it's thicker, it goes flush with the skirting boards and looks ugly.
OK, so you don't skim over orifinal lime plaster, but what do you do if someone's already done it? I'd imagen trying to remove the new plaster would cause loads of damage the the original plaster below.
Also, on some external walls, there is some kind of old lining partition - I haven't poked through it to investigaate yet, but I presume its lath and plaster. in parts, this has been removed - the skirtings wave been added to and the architrave around that side of the wall is twice as deep. The difference between the hollow lined wall and the solid sounding one is about 7 cm
I presume it must have got rotten, so the previous owner removed it. Do you think that could be the case? Did laate Georgian /early Victorian buildesrs do that? If so, what would you reccommend I do once Iv'e stripped the wallpaper off? Reinstate the "original wall insulation"? leave as is? or remove the insulated parts, as this must be say a 1950's adittion?
