Keithj
- Witnesham, Suffolk
I've mentioned before that the firm that carried out the major repairs on my house did a fine job, until towards the end when the boss was trying to make a bit more money on the deal and started cutting corners. One of those corners was using plasterboard and gypsum on the inside of south and west-facing outside walls where the exterior is lime, and where the lime is "inset" from the plates and studs.
Water pools on the little ledges thus formed, and blows through the wall when it's seriously windy. We end up with "tide marks" of a darker colour staining the bottom inch or so of the inside walls. The rest is OK. There are gaps under the lime where the green oak has shrunk, but I've been filling those each summer and the gaps are now almost non-existent (but enough for water to blow through, needless to say).
Last month, I washed off all the stains, and repainted. It looked very good for a week or so. Then we had a mighty rainstorm and wind, and the tide marks are back again.
I'm wondering what to do (other than just "repaint", as the preacher said). One thought is to chisel off the bottom inch or two of gypsum, back to clear plasterboard, and re-render in lime. I'm inclined to have a little experiment in a corner of the kitchen behind the table, where it wouldn't be too noticeable if it all went wrong.
What is the view of the panel? Would there be other problems where the gypsum and lime meet? Would it prevent the tide marks?
