Well, everybody says this, but I've had ivy for twenty odd years and my old, soft, bricks still seem fine! It makes a nice fedge too (combination fence/hedge) for screening/windbreak purposes. That said, it can be rampant and when one of fedges finally came down ("hurricane" Kate) I was chopping out ivy stalks thicker than my leg!JoceAndChris said:Ivy has aggressive brick crumbling roots though, you don't want that!
Yup, that's what we've got. Though I used plastic-coated green wire wrapped around brass screws to give the C+H something to twine around.JoceAndChris said:Nicely mounted trellis and a Virginia creeper looks nice! Clematis and honeysuckle too. Lovely.
Because lime is softer and more easily damaged? Or it'd get in the way of periodic rewashing?JoceAndChris said:I'd do it on cement render, not on lime render though.
Did that too! It can be howling a gale and still relatively calm in our garden. I'm already, mentally, planning my planting for any new place we get. If we get one, sigh.JoceAndChris said:Trees and high hedges are good for sheltering buildings too.
Yup, been there, done that, when I was young and green. I only grow the low-growing varieties up walls now, though I find you can usually double whatever size the label gives as maximum height!JBean said:Hmm, not such a fan here. About 20 years someone planted a clematis montana on the rear corner of our Edwardian house. By the time we moved in, it was all over two sides of the house, rampaging over the top of the bay window, blocking up all our lovely timber gutters and trying to find a way under the roof tiles.
jocelyn plummer said:I have one word only for this thread----Wisteria --------- perfectimo
There was a huge amount of ivy on the front of my house, up to the slate roof, inside the loft, blocking windows, splitting gutter joints etc, and I was amazed that it had only penetrated the limestone wall in one place (below ground); the entire wall was in lovely condition having been protected by the thick ivy. However, the ivy on the similar garden wall was recently removed (by my neighbour) and this has revealed a wall that needs to largely rebuilt - there are many roots which have penetrated and basically there now is very little mortar on the top three feet of the wall, and lots of loose stones.JoceAndChris said:I like plants up walls. Ivy has aggressive brick crumbling roots though, you don't want that!
Mrs H likes it, but I'm not so much of a fan as I think the woody stems too dominant.pip&mims said:Some piccies of the wisteria we inherited when we bought our current house.......
Hear, hear!88v8 said:Climbers integrate the house into the garden.
Hadn't thought of that, useful suggestion, thanks.88v8 said:Petiolaris - climbing hydrangea - is great on a north wall. Left unchecked and with a moist root run, it can grow to 100ft, but it clothed the north wall of our previous house for 30 years.
Waterproofing, definitely, it's why I planted it here. Sun - hadn't considered the effects of that I must admit. I also assume that (big) plants against a wall will help keep the base of the wall dry (probably especially important with a cob wall), though no doubt there's a balance to strike between dry and too dry.88v8 said:Ivy waterproofs the wall. It shades the wall from the sun - the sun is a great destroyer.
Another useful tip, thanks. Maybe I will be able to grow stuff up a limewashed wall (if we obtain such)88v8 said:If a climber can be grown on a trellis, the trellis can be hinged at the bottom to facilitate maintenance of the wall. This has its limitations. A very old climber will eventually become too woody to tolerate bending, but this will take many years.
I find one of these v. useful - https://www.henchman.co.uk/products/hi-step-platforms.htmlmalcolm said:but is now trimmed once a year at a height that does not require a ladder. (Or should be - I forgot this year and it is reaching roof height.)
