bustergreen
- Cornwall
Hi everyone,
Me and my partner have recently brought a 1850s cottage in Cornwall. It's split on 3 levels, the lower has one wall completely under the ground, two walls are adjoined by two other cottages in the terrace, and the third opens up to a kitchen which is at ground level.
We knew the room suffered from damp when we brought it so are not surprised by that. How ever when we pulled the carpet up you could see some of the original granite flag stones underneath a sandwich of cement screeds and some sort with some bitumen lining. We decided to remove some more of the screed to reveal the stones, whilst initially most of the stones were dry, they now seem to be absorbing whatever moisture is in the ground. Since this has happened there is now a lot of condensation forming on the wall which is underground. It's all been tanked with some kind of special paint, apart from a strip behind a rayburn and another where the stairs meet the wall, everything down there is cement render and then painted again with some sort of plastic paint.
In an idea world we would like to get rid of all the cement and plastic stuff and go back to the stone and lime. But we are a bit concerned with the amount of moisture appearing. So we are a little dubious to continue incase we open a even bigger can of worms.
Just looking for some advice or some one who has done something similar and could let us know how damp things got before it all dried out (if it did).
