Singleton Birch said:Natural Hydraulic Limes are currently classified according to 3 European grades:
Natural Hydraulic Lime 2, abbreviated NHL2, Natural Hydraulic Lime 3.5 (NHL3.5) and the third is (NHL5).
These grades are based upon the strengths the materials achieve in standard laboratory tests, so the higher the number the greater the strength. However each grade can have a minimum and maximum figure and to make matters more confusing the maximum figure for one grade can be higher than the minimum of the next grade up. In other words the grades overlap.
The hydraulic limes given above are produced from naturally occurring limestones. It is possible however to achieve similar results by mixing suitable materials and in this case the materials can only be classified as Hydraulic Limes abbreviated HL. Lastly it may be necessary to add additional pozzolanic material to increase the strength of an existing NHL2 (or 3.5 or 5). In this case a Z is added. Eg NHL3.5Z
This information is contained in a British / European Standard, BSEN 459 Part 1 2001 including quality control regime for testing.
