CliffordPope
I have bought a pair of ornamental drive gates, spanning an opening of about 10 feet. Each gate is about 5 feet wide, and around 8 feet high, weighing 180 Kg.
There are no gateposts at present, and I want to build, or have built, a pair of nice solid pillars in reclaimed brick. Each gate will sit on a ball-bearing support at the bottom, bolted at ground level to a projecting part of the concrete footings. There is a strap hinge at about 6 foot off the ground, with a V-shaped bracket to be cemented into the pillar at the appropriate level as construction progresses.
My questions are:
What volume/size of foundations will I need? I presume the easiest is to dig a large hole and fill it with concrete to ground level, and then build the brickwork on that base?
What width of pillar should I specify? Two brick-lengths looks very slender, 2.5 or even 3 bricks looks chunkier. How can I calculate what weight a pillar of given dimensions will support, hanging at that height?
Any advice or experience would be much appreciated. Probably I will just hand the job to a builder, but I'd like to know in advance what sort of principles and dimensions are involved.
My questions are:
