MatthewC
- Central/South England
I have a new neighbour (not the other half of the semi but the other side). They have done a phenominal amount of work on their place in a very short space of time (mostly based on the right principles).
One of the things they have done was to remove the huge amount of ivy on the 18" thick roughly squared limestone wall in the garden between their property and mine. Sadly, this has revealed that the wall is not in as good a condition as I thought. Part of the wall was clear of ivy and is indeed in pretty good condition; however, the 5 linear metres of wall under the ivy is very poor with lots of loose stones, poor pointing and ivy disappearing into the wall. Moreover the wall is leaning in their direction by possibly 8 or 10 inches...
The trouble is that the wall is pretty big. My side is about 8 ft high, and their garden is probably about 3 ft lower than mine, so they have an 11ft wall towering over their patio. A major rebuild is definitely needed; legally I think it's their wall, but it's my ivy. Both houses are listed and in a conservation area. A like-for-like repair does not need LBC, but the question is whether any building regs apply? I think there is a rule about having to be authorised if the wall is over a certain height (2 metres above highest ground?) but does that apply to repairs or just construction?
Truth be told, it's so high that I think I'll find someone anyway, rather than do it myself as next year's project. I wouldn't want the responsibility if it fell over later.
