Seanie_230
Firstly thank god for finding this forum that is dedicated to older houses
my house was built in 1903.
I have put a picture of my front garden below.
As you can see it needs some tlc, I'm thinking of digging out the soil (already started) and then filling it in with some hardcore and cement and putting victorian quary tiles over it so it looks authentic and does t look out of place as the house is 1903.
My question is where the original path is cracked should I pull it all out and lower it and start again with fresh cement?
Or is it better to screed or something over the top and fill the mud area level with the existing cement.
I am going to use some original rope top edging around the hedges.
The house has been damp proofed at the front with the injection stuff but if I cement upto the wall and use tile grout right up to the brick will this stop water sitting and soaking into the bricks.
Also as you can see the path is the same level as the big old step. should i add a layer of cement to the step as the quarry tiles will be higher than the step.
Can anyone offer any advise i want to keep my garden looking nice and not to modern for the house.
should i leave a gap between the wall and the concrete with some pea shingle or use grout for the tiles to stop trapping water between then cement and brickwork?
