billybuntus
Hello,
Been lurking on here for a while and I thought I best contribute. I'm currently around 2 months into what started out as replacing my front door and timber surround. We looked to have the front re-rendered. Then struggled to get a match to what was applied to on of the house gables some 3 years ago. In the end I thought I'd try and point the rubble stone up....And here began my quest.
Firstly this is the door that is going onto the house. After much hand stripping by me.
Under the layers of paint is a lovely coating of scumble glaze. I'm not old enough to know why it was ever invented but my uncle reliably informs me that their were a few men who could do a fantastic job on making pine look like walnut or whatever was your chosen timber 'look'.
When heated it turns into a sticky mess then is difficult to remove
I've scraped as much as I dare for now and used a stanley blade to scrape in the fine grooves. Still a long way to go.
After applying lots of elbow grease and water based stripped I'm now here...
The door was thoroughly hosed down with water then a final clean with methylated spirits. Sanded with 120 grit paper and spot coated (knots and edges) with zinnser bin then two full coats using Zinnser 123. It's had one top coat but no pics until it's hung
