overlander matt
Before the wet weather arrives I want to restore our front door and portico... It looks a bit tatty and it's time for a change of colour. The style is a bit unusual - nobody seems to know what it is. Is it original? Who knows but it has probably been on our house for a while. There's a fair amount of rotten timber to replace on the portico where the lead is cracked and I'll be replacing damaged mouldings on the door and portico side panelling.
The first question I have concerns the two plinth blocks that partially sit on the top step. This doesn't really look right and I'm wondering about whether to just match it with the replacement blocks. Both the top and bottom of each block are pretty rotten. I'm wondering whether I should try to bring the blocks down to the step below or maybe add some brickwork under the unsupported ends. The current detail doesn't look right. Any suggestions would be welcome thanks. We also get a bit of water ingress under the door - would a weather bar look right? Some Georgian doors don't have them so wondered what looked right.
After a few hours with the heat gun, scrapers and sander today I have made some progress removing the old brown paint and woodstain on the door. I've removed all the mouldings and will refit what is reusable and replace the damaged with some new moulding to match the original. I've not done a huge amount of external wood repairs with filler at this house - what is the best type of filler for repairing small holes and flattening the surface in places where the grain is very pronounced? It's particularly uneven on the panels making it a bit difficult to remove the old paint.
Thanks in advance for any advice or guidance you can provide.
Matt
Matt
