Ushy M
- South Northants
We have damp on the inside of our gable end wall because the ground level is higher outside due to it being in the churchyard. I've posted with enquiries about constructing a french drain before and we are now planning the project out in more detail.
One thing that bothers me is that the recommended construction method I've seen (IHBC paper) emphasises the need to dig the trench walls at 45 degrees. We need to dig about 3 feet down and can only dig a very narrow trench because the nearest burial is only a very few feet away from the house wall, so constructing such a trench with walls at 45 degrees is impossible.
Any help or advice on how to overcome this or otherwise equalise the ground level and allow the wall to breathe in such a narrow gap would be gratefully received. I've seen a reference to creating a "dry area" - could this be an alternative approach to a french drain?
