TudorCottage
- Bedfordshire
Good Evening
Due to pooling water in heavy rain I’m in the process of renewing the French drain system around our cottage.
The current system comprises of 2 60mm drains laid side by side with a membrane just laid across the top of the drains rather than wrapped around them. It feeds into a soak away approximately 15 metres away from the cottage, the new drains will follow the same route.
I’ve removed the old drains and now have a blank canvas to replace with new drains. Space is not tight and thought I’d gauge opinions on here.
Is there any benefit in increasing the size or the number of drains?
i.e 3 x 60mm, 2 x 80mm or even 3 x 80mm. I think 100mm is getting too big.
Also, I’ve lowered the path to the bottom of the stone plinth and after digging a further trench for the drains was going to back fill with 20mm shingle back to the top of the plinth. Is there any advantages/disadvantages of going lower. It’s soft clay so whilst not easy it’s not back breaking.
Thank you for any opinions.
