plumbers mate
- Frozen north
I think this is called the foul waste vent pipe.
Not sure about proper name. There used to be an outside toilet building in the back yard and it had a cast iron pipe from the nearby drain. This toilet was removed about 20 yrs ago and the vent pipe is in the way. I want rid of it. (There is a vent from the waste of the indoor toilet of course)
Now - How do I get rid of this 4ins diam 9ft tall cast iron pipe?
If I don goggles, hard hat, boots and gloves and clout the pipe near it's base with a *big* sledge hammer, will the pipe shatter so that I can break it up? Would I need to put a dust sheet around it to avoid too much flack flying around the yard (bearing in mind I've just had the windows done and don't want a piece of CI flying through the glass or decapitating my runner beans).
It has a good strong bracket holding it to the wall so hopefully wouldn't land on the hard hat which wouldn't really save the head underneath.
The hole left in the yard would be filled by the patent method of a plant pot full of concrete (it's a victorian concrete YARD so concrete is the proper material - limeys!) as was done when the netty was taken out.
A helpful friend said use a hacksaw - he'd never heard of cast iron pipes and though they were all plastic - some friends make me feel so very old.
