wrongfoot
- Northumberland
Hello everyone, My first plea for help...
From reading other posts I gather that some people like to have a context and others want questioners to get straight to the point. If you're the former please read the italics and if you're the latter skip them :wink:
I own 2 identical semi-detached 2 storey properties in Northumberland. They aren't listed or in an AONB or coservation area. They're primarily built with >0.5m walls comprising sandstone blocks internal and external (with a rubble fill also of sandstone) laid with lime mortar. The walls have been "repaired" and pointed with OPC in places which I will replace with lime mortar as it fails in due course. The walls show evidence of injected DPC on the inside behind the skirting. Not what I would prefer but you get what you get with old properties. I gather this injected "DPC" is unlikely to be effective on sandstone with a rubble fill but that's no bad thing since the walls should still breathe (if a little less than before) protecting the foundations. Inside the exterior walls a lot of the lime plaster on laths has been skimmed with gypsum or replaced with gypsum plasterboard and similarly skimmed. Stud partitions are all modern plasterboard with gypsum skim. Whatever the original ground floor once was it has been removed / replaced / overlaid with OPC slabs almost certainly without insulation or a DPM probably on a room by room basis. There must be plenty of properties which were victim to such "improvements".
There is a single storey modern-build flat-roof extension out the back with cavity walls / cavity insuation also on an OPC slab.
Despite all these changes there is no evidence (so far) of damp in the sandstone walls and only black mould from surface condensation in on the walls of the modern extension which houses the kitchen and bathroom. I hope to address that with better and more continuous heating (installed already) and ventilation.
So much for context.
My problem is that I'm in a quandry about how to floor the older / main part of the property. There was a bamboo tongue and groove solid wood floor in place glued to the concrete but this had lifted in part on higher tread areas and when I lifted it I found some areas of black mould, some efflorescence and spalling of the slab / screed patches. Mostly at the furthest distance from the hearth but also visible along wear areas. It's difficult for me to determine whether these symptoms of damp are due to condensation from the room, wet carried in on feet or from dampness in the slab. I suspect mostly condensation from the room because the old Parkray wood boiler in the hearth was run very intermittently by the previous owners and the uninsulated slab and stone of the house will not have warmed, but obviously I can't be sure.
So what flooring do you recommend for a cash-strapped period property owner?
I'd prefer to install modern laminate flooring over the current OPC slab but I'm open to other flooring types if they are better suited. I'm concerned that if I install a laminate / wood / engineered wood over a vapour barrier sheet that may push moisture breathing from the slab to the walls and cause damp issues there? Or alternatively that if I install those floor types without a barrier sheet they may swell / blow.
Vinyl type floors / tiles seem to be vapour barriers themselves and may trap moisture and convey it to the walls just like a vapour barrier sheet.
Glazed tiles don't breathe at all, although I can ensure the adhesive / grout does. Is that likely to be enough breathing?
Terracotta parfits etc. wouldn’t be in keeping with the locale but might be the best option. Are there other breathable tile options that are affordable?
Flagstones might breathe depending on rock type, but, oh my, quarried rock tiles are expensive!
A timber floor above the concrete with an air gap would raise the floor too high and I’d be dealing with lower doors / ceilings and staircase issues.
I want to be reasonably sure that a floor type will work in the environment of my home. Am I missing a simple breathable floor solution? It looks like there are a lot of practical and knowledgeable people here, any advice welcome including any links to forum threads I haven’t had a lot of success searching this site.
Thank-you.
Thank-you.
