Vic Wintergreen
- Sittingbourne
150 year old Victorian Terraced property
First floor
I have lifted the floorboards to put in a foil backed platsterboard wall. Spaced 25mm from the wall. Plasterboard extends below the level of the floor and above the level of the ceiling so there is a continous airflow path from below the floor into the roof void.
I was going to seal the gap between the floorboards and the wallboard with decorators caulk (this will be hidden by the skirting) and seal the gaps between the (straight edge) boards with a propriety gap sealant (Ronseal)
I have screwed the floorboards down with 10 x 1.75 brass cs screws
I have lightly sanded leaving some patina and character on the floorboards
I want to fill some of the deeper holes and would like some advice on the best filler for this job
After everything is complete I want to lightly sand then wipe down with boiled linseed oil mixed 5-1 with white spirit and then finish off with a floor wax
There ya go.
Have I made any mistakes (screwing vs nailing, sealing vs not sealing etc)
Do you have any other advice
Thanks in advance
Vic
First floor
There ya go.
Thanks in advance
Vic
