hello, a quick question. What type of floor structure would you expect in the vestibule hall of a typical victorian terraced house (the area by the front door usually laid with geometric tiles). Ours appears to be solid, but the holes in the front door step look like air vents and suggest it is a solid floor over joists. Is this likely to be the original structure? and if so how was it built
thanks
thanks
