Brightonian
We recently bought an old farmhouse early 1700 and 1800’s. The outside was higher than the inside floor (14 inches) and was originally built into a hill. So far we have lowered the level outside to the same height as the floor (didn’t want to go lower because of the lack of foundations although the builder tells me it appears to be built on bedrock) and put in a retaining wall two metres away from the gable end of the house which faces a rather steep hill with a French drain at the bottom of the wall.
The gap between the wall and the house has been gravelled and the down-pipes have been diverted to soak-away. This appears to have made a huge difference to the floors inside and they are now drying out – previously they had a puddle !
Now turning my attention to the inside. The existing floors appear to be made of concrete and lime dust. Current thoughts are to:
• Replace all the hard floors with limecrete or
• Put in a hybrid floor with concrete in the middle and limecrete around the edges
• Install UFH
Issues and concerns around this include:
Expense
• How much more expensive are limecrete floors generally than concrete ones as a rough percentage (I have circa 60 m2 to do)?
• How much would be saved by using LECA (lightweight expanded clay aggregate) as opposed to recycled glass and what would the differences be in the corresponding u values (negligible relative to the expense or worthwhile)? Plus would it adversely affect the finish if I went down the polished limecrete route (is LECA better than glass or vice versa)?
Breathability
• Are the advantages of breathability overplayed particularly when the limecrete is covered? Even the flagstones I have for one of the floors would leave a very modest area with joints.
• What practical floor surfaces (not easy stained or dusty) could be used to preserve the breathability of the floor?
• Can limecrete be polished to provide an acceptable/aesthetically pleasing and practical finish ?
Hybrid floor
• Is it a practical solution in terms of both of the above – gets breathability to where it is needed most (the outer edges) and minimises costs?
UFH
• Would limestone bedrock be an inhibitor or would it actually help if left in place / incorporated within the floor where possible (seen as part of the insulation/slab)? We had to dig/drill loads out from the outside when putting in the drains! If it helped or was neutral, it would cause significantly less disruption to the building and save on both time and materials
• How well does the building have to be insulated to make UFH worthwhile (I was intending to put radiators upstairs and include some downstairs in addition to the UFH). The plan was to heat the building via a boiler stove and an oil boiler (although looking into GSHP). Is it a case of every little bit helps or the benefits of UFH largely negated if you have to install radiators as well?
• Finally can UFH easily deal with floors on slightly different levels (anything to be aware of) and what does it typically cost over and above the cost of installing the floors and the screed?
Any tips and advice on the above, including recommended suppliers, would be greatly appreciated.
Many thanks
Har
• Install UFH
Expense
Breathability
Hybrid floor
UFH
Many thanks
Har
