Thatspellstrouble
Hi guys
Hope you had a lovely Christmas!
In the new year I’m getting around to putting a woodfloor down on the concrete downstairs.
I’ve not noticed any moisture coming from it but to be on the safe side I was thinking of doing a floating floor so if any moisture was forthcoming it’s spread across the floor instead of concentrating under a membrane and going into the walls? Though I’ve seen posts on here suggesting it’s better the latter way.
Also would it matter if it was solid wood or engineered wood for this? Assuming no moisture then I suppose it makes no difference but if there’s a slight chance… would solid wood fare better?
