Can anyone give any advice about how to resolve a conflict between the part L requirement to insulate walls and the desire to refinish with traditional finishes?
I am renovating a nid 18C flint cottage. The cottage has in the past been painted on the outside with a masonry paint. I am told that this would be impossible to remove without causing damage. On the inside the walls were originally lime plastered. At some point the internal walls had been covered with pine wood panelling with loft insulation behind the panels. On removing the panels , the walls were found to be very damp and the plaster was falling away. Once we removed all the cladding and the plaster , the walls dried out and we are now repairing the walls and the brickwork around the window openings.
My builder tells me that under building regulations part L we are obliged to dry-line the walls to provide insulation. I am worried about this for two reasons:
1) The walls will no longer breathe and therefore the damp will return, leading to even more deterioration in the fabric of the walls.
2) The rooms are already very small with window reveals that are about 2ft wide, adding a further few inches of stud and plasterboard will make the rooms even smaller and will give window reveals totally out of proportion to the size of the rooms.
Do I have any options about how to resolve these conflicting requirements? I would have liked to just re-plaster the original walls in traditional materials, thereby allowing them to breathe. However I realise that this will not meet modern insulation requirements. However the dry-lining option will I believe lead to further problems.
HELP! and thanks
HELP! and thanks
