We have some secondary glazing - PVC sheets with a rubber seal held on by clips. They're in a pretty bad state of repair and I'm reluctant to put them back up.
I've been thinking about options and wanted to run past you all.
Flexible 0.5mm PVC sheet, cut to size with magnetic strip around all sides with magnet stuck around frame.
Pros - lightweight, easy to store, easy to remove, airtight
Cons - may not be taught so visibility impaired, may not keep well over summer rolled up, might not actually work(!).
