luckyt1982
Hello
We have recently moved into a 1850 ish property. There is flagstone floor in the living room, following into the kitchen.
We are aware of damp (been diagnosed as rising damp by one specialist company, but I'm going to get a second opinion after reading the rising damp myths!) in the kitchen. There are areas where the plaster is blown and having scrapped off the bubbling paint and plaster, it looks damp.
We have also noticed moisture coming through the grout in the flagstone flooring, mostly confined to the areas near the 'rising damp' in the walls, but also a few other areas. The floor is quite worn in the kitchen area and the 'grout' is perished. We can see a plastic sheet coming through in one corner of the kitchen, which I assume is a DPM.
My question is - is it 'normal' for moisture to come through flagstone flooring and its grout? If not, is there any treatment that can be done without ripping up the floor and replacing the DPM?
It might be that the 'rising damp' in the walls is finding it's way into the floor - so the issue might be solved when we have this sorted.
