We are in the process of re-plastering a wall in our kitchen and  for practicality I want a section of the wall tiled.
The scratch coat was a lime putty mix directly on to rubble stone walls. We have discussed with the builder fixing the tiles directly on to the scratch coat and then having the finish coat applied to the same depth as the tiles. In this way there will be a flat finish with the tiles level with the plaster.
He has suggested trying to stick the tiles on with a finish coat of plaster, rather than using tile adhesive and then grouting with a fine lime plaster mix to maintain as much breathability as possible. I think this sounds like an interesting idea, but will it work? Does anyone have any experience of this, or any thoughts?
Thanks.
Thanks.
