Nigel Watts
- London N7
Does anyone have any good tips for fitting sockets into lath and plaster stud walls without resorting to plasterboard?
I was trying to install an ethernet socket this morning. Having carefully threaded the cable down the hollow wall from the roof void (with not a little smugness at avoiding the need to doing any chasing in) I tapped at the plaster where the socket is to go and ended up with this:
When my builder had installed the double socket, which is in front of a stud, he had packed the void behind with large amounts of scrunched up newspaper and then filled the entire space with a block of gypsum plaster. Being directly behind a socket this strikes me as a fire hazard. I need to fix a socket box and replaster in lime.
