one side of the frame is about 2 inches of thin air between the frame and the old house which is wattle and daub and the other side of the frame is an old clay lump wall that isnt very strong at all , so basically i have nothing much to fix the frame to on either side.
the frame is 90x90 mm oak and the top part is fixed with mortice and tennons to each side piece.
any ideas on how to fix this in to position? i have thought about putting each vertical side piece down around 6'' into the ground then filling in with lime cement to try and hold it into position , any thoughts?
the door will just be a bog standard wide oak plank ledge door.
