So, all going to plan we should have our first restoration project by this time tomorrow. Its a 1850's Victorian cottage that is in need of total renovation so it's a real blank canvas.
We are on a budget, so certain things will need to be done either as and when, or with cheaper alternatives.
We had a full survey done prior to buying and it pretty much confirmed what we thought needed to be done (everything) but I'm a little concerned about certain aspects of working with older properties.
Roof
The roof needs relaying - there is no insulation. I am concerned that relaying the tiles together with an underlay and insulation may cause issue with damp not escaping? If a breathable membrane is used, is that ok? Is there insulation that doesn't cause problems?
Walls
It is a solid brick construction. In order to aid with bills I was thinking of using insulation on the inside walls, insulated plasterboard maybe - would this cause issues with damp?
Externally, there is some pointing and brick repairs that appears to have been done using cement. Not sure if it is lime cement. If it isn't, should it all be removed and redone with lime cement to prevent damp on internal walls?
There are vent bricks externally. No apparent DPC and typical surveyor recommend an injection of DPC (I didn't check he was versed in old properties).
Floor
Quite a lot of solid quarry tiled floor and one timber floor. Surveyor recommended a damp membrane and then a solid floor laying on top. Will this work to prevent damp coming up or will it push it to the walls?
Skirting on ground floor and first floor are apparently concrete which surveyor thinks was due to damp.
We intend to have composite wood flooring as the covering and victorian tiles in the hall (remember cost is an issue).
Heating
Not sure where to go on this. It's currently Elec heating and off mains gas. Builder has suggested gas tanks but not sure on it. Neighbour has had a GSHP installed as there is a big garden available and he said he is going to get £35k over 5 years back on the RHI scheme. So could maybe do that..otherwise not sure.
As we need to do an extension, thinking of maybe doing underfloor heating - would this affect damp problems if heat is on more than normal?
This will no doubt be the first of many posts - Thanks in advance for the answers.
Roof
Walls
Floor
Heating
