Feltwell
- Shropshire, England
Feltwell Towers is lucky to have lost relatively few of it's original features compared to many other Victorian abodes, however one thing it has lost is it's fireplaces. Only one original, intact, in-situ fireplace remains in one of the bedrooms. There was also the broken remains of one boxed over in another bedroom, I confess I broke it further getting it out
but it was in a bad state anyway.
However - those 2 fireplaces revealed that my house had "Biclam" (Bennets Iron Company Limited Ardwick Manchester) design No.54 cast iron combination fireplaces, and since then, 6 years ago, I have been scouring Fleabay every week for other examples so I can re-instate fireplaces that are identical to those that were there originally. I've had to assume that the downstairs lounge & dining room fireplaces matched those upstairs, and the plaster on the chimney breasts has given me what size fireplaces the rooms had.
In doing this I've been up & down the country collecting various, mostly incomplete, fireplaces - and this week I'm collecting the last one
, which will give me enough bits to build a fireplace for the dining room (which will work as originally intended), another for the lounge (which I'll probably put a gas tray in for a "living flame" gas fire - we've got one in a reproduction Victorian surround at the moment and it's surprisingly realistic & good at heating), and another for one of the first floor bedrooms which will be decorative only. Another of the first floor bedrooms has the remaining original fireplace, and the last bedroom on the 1st floor won't have a fireplace as it's layout is such now that the only place to put a bed is up against the chimney breast, due a door having been added in that room to an en-suite bathroom - one of the very few changes to this place.
Whoever slept in the two 2nd floor bedrooms were clearly made of hardy stuff as they slept beneath the uninsulated roof, with only what feeble heat rose from below to warm them - no fireplaces were ever put up there!
Anyway - to end a long ramble - has anyone got any period "how to install a fireplace" instructions? Needs to be for a cast iron combination fireplace, i.e. the insert, mantlepiece and surround are fixed together and fitted as one. I've seen some modern instructions but wondered if anyone had any old books with instructions in.
The gas one will have to have the gas connected by a qualified fitter (flue already lined for the current gas fire), but the solid fuel fireplace, whilst strictly speaking should be fitted by a HETAS engineer, I fancy fitting myself. I'll get a sweep out to double check the (unlined) flue for me but it's not given any problems before and has been swept. CO2 alarms will be put in all rooms through which the flue passes.
This is the style if anyone's interested - although the firebars on this one aren't original, they were a more angular design. Not my personal favourite but it's what the house had and it's very typical of the period.
http://www.fireplaceantiques.co.uk/Product/Late-Victorian-Combination-Grate-in-Cast-Iron-/10830
