Roger H
- Northumberland
Hi all. The previous 'custodian' of my unlisted, 1840s sandstone Northumberland cottage did a variety of unsuitable works. Notable among these was boarding over the bedroom fireplace, and stuffing the smashed up mantlepiece into the void. Now, I know very little about the detailed construction of fireplaces so don't know how to assess the current condition of this one, or to visualise what is missing and needs to be put back. I've a few questions I'm hoping you can pitch in on:
The mantlepiece is in pieces. Is it beyond sensible repair or could it be pieced back together with a suitable resin, maybe supported by some steelwork and reinstated? See below partially reassembled jigsaw.
The opening is as below. There is a shallow brick arch behind the plasterwork - I'm unsure if the wood is doing much, or was just studding for the plaster infill panel when the fireplace got taken out. There is no sign of the jambs to the fireplace.
Showing it in more close up the fireplace has almost nothing left but its brick flue and some stone flanks. There is evidence of some metal plates on either side about a foot of the half. What do they suggest about the format of the original fireplace?
Any ideas on what is missing and what might be reasonably put back? The hearth is present under the carpet and I'd be content with a functioning fireplace, potentially a woodburner or even just a non-functioning fireplace. Many thanks, Roger
p.s. And they ribbon pointed the shed in cement! I know.
