Hi,
I am nearly ready to finish off my fireplace - I am just going to sit a fire basket straight onto it, but as the brickwork is poor I want to render the inside - anyone know the best mix of lime/sand/cement? I understand it should be a weak mixture so as it doesn't crack when the fire is burning. Where do you get lime? None in Wickes as far as I could see. Should I render as far up into the chimney as is possible? The mortar looks a bit gappy.
Also - am considering tiling the inner hearth - can you use natural slate...or patio bricks? Or those small red natural finish quarry tiles?
thanks
js
thanks
js
