Roger H
- Northumberland
People may remember my opening up of a boarded up fireplace in our much-abused 1840s stone cottage. I finally got around to reinstating a fireplace. Here's the process. When we moved in:
Sadly, the fireplace was gone.
One of the jambs was in the garden an inch under a flowerbed :shock:
The Mrs decamped elsewhere for three days. Admittedly encouraged to see the back of the sheet of plastic duct taped over the opening that we have lived with for over a year.
I had a new jamb cut to match the survivor, and a plain lintel made up. The hob grate was £16 on ebay. Looked a lot better when I had the pink gloss paint stripped off it. Here are the jambs being positioned. A learning curve was that I needed to clear out the backfill which had been behind the orginal jambs to enable mine to be sited comfortably. This was then replaced with stone and a loose lime mortar.
The lintle was a hefty three man lift.
And the finished job, with some stovex polish on.
Electric socket still to move, and lime plaster to edges to put back.
