The Plan is to expose and repoint and either use as a feature or put a bioethanol stove in the space.What's your plan for the chimney?
Install a wood burner and expose and repoint the brickwork?
You might find a curved iron bar under the arch
Thanks, the header brick at the top of the triangle does appear to have had work done to it. For some reason it has a piece of slate running across it and the rest if the mortar is slate coloured .I wouldn’t be happy with just pointing, that’s an aesthetic not structural repair.
Lime, no place for cement here, although a very weak NHL would be probably ok given the setting.
I can’t work out the original form of your arch, as the bricks don’t appear to be cut/rubbed enough to form a solid curved shape with adequate contact, it almost looks like the centre needed a v shaped ‘keystone’ equivalent, which simply shouldn’t have been the case when built. Either way the arch looks like it has dropped a decent way. As you look at the photo, there appears to be missing brick on the pier, which should be taking the contact with the arch.
I would also be suspicious of the central header at the top of the load bearing triangle - looks like it has been meddled with from the differing coloured mortar. Presume the arch has dropped and repairs have been made without resetting the arch and this brick has dropped as the new mortar around is also wider than it should be.
Personally, I would be replastering in lime as these bricks were never to intended to be seen. An iron bar under arch packed up will give support from below. A lintel above a failed arch will help the stack, but the arch will probably still drop out further. And rake out the loose stuff only in the joints and if it’s in the range of 10-15 mm then just repoint in one go, almost flush finish but I prefer a little depression to help with the key for the scratch coat. If you choose to limewash instead, then point flush.
Assuming you’re pulling off a nasty rigid modern plaster, what happens at ceiling level where it meets the cornice, assuming it’s original? Care will be needed here too….
Stuarts right; iron or steel shaped to the required curve, with 'spurs' that would sit in the columns, would sometimes be used to provide support for the brickwork above. However, more often than not these were used instead of a wooden form and were regarded as a one time use tool for the purpose. These can be installed after the event but that may require the removal of the brickwork above to allow installation. Such irons/steels are relatively easy to make if a suitable fabricator or smith can be found.You might find a curved iron bar under the arch which adds stability.
Yes, a lime mortar is perfectly appropriate but I would check first that the original mortar is lime based first by testing a sample with some vinegar.Thanks very much. Yes I've been thinking it's not a good idea to remove the block work until I've repointed the rest of the brick work.
Do you know if i should use a lime based or cement based mortar?
Slate commonly used just to fill a gap too large for mortar alone, particuarly in the horizontal as it’s strong enough to pack out the gap crated by the dropping brick courses…Thanks, the header brick at the top of the triangle does appear to have had work done to it. For some reason it has a piece of slate running across it and the rest if the mortar is slate coloured .
