I'm opening up a fireplace and have found a lintel underneath a double arch, which I'm puzzled by. Is it structural, for hanging pots and stuff off in the old days, or just to support the brick work that was between the lintel and the arch? There is some old pipework underneath one side of the lintel, which had only loose mortar packed in, which I've removed some of. The lintel seems to go into the sides by only about half a brick each side, but some of the brickwork underneath is missing where the pipes are. Can I remove the lintel without worries? Will I have to prop anything before build the sides back up?
