Hello....I've just had two fireplaces installed. One is gas and the other a real (solid fuel) fire. I believe the hearth for the solid fuel firepalce has to be made from a more substantial (solid??) material to withstand the heat a real fire can put out!
My question is about the cementing of the hearth's to the floor . The fitter has used a fair bit of cement thus raising the hearth about an extra 1/2" or more (not so much on the gas fire) I'm assuming it has to be fire resistant cement and was wondering if this made a difference? I was also wondering if more has had to be used as its a heavier hearth. I'm also aware of the fact of getting the hearth level.
I guess I am trying to find out if this amount of cement is acceptable and necessary or whether the fitters been slap dash about things. Have to say apart from that it is a good job (well I won't mention the poor job of reapplying the skirting!!!!!!) but as I have original floorboards (Its a Victorian property) it is noticable, which it probably wouldn't be if I had fitted carpets which isn't a road I won't to go daown!!
Any comments would be appreciated.
