Victorianhome
Hiya, I’m just busy prepping for our woodburner install and the back wall of the chimney board is lime plaster on stone (the sides are bare brick). The stone is very uneven so the plaster works to level the wall out.
I believe the installers will use hardie backer cement board to line the recess which will be tiled but I’m wondering what would need to be used to stick the board to the lime plaster? Any ideas gratefully received as the installer would probably just use their normal materials but I’m not sure if mixing will cause something to fail. Thanks!
