jimbom
- Gloucestershire
We have recent moved in to a former cotswold convent, having purchased it from the nuns....
House needs lost of work!
One of our first projects is to get a fireplace operational, before the real work starts next year.
The fireplace has been blocked up and a sheet of wood fixed over a small hole, this I suspect was for a gas fire at some stage. I have had a look inside and concrete blocks have been used to fill the opening with a concrete surround at the base which I assume the old gas fire sat in.
I am looking to fit a cast iron victorian inset into the fireplace, but first I need to remove the existing mantle and surround, can anyone advise on how this would have been fitted?
Is it a case of being screwed in and plugged over the screws or would it have been attached by brackets set into the plaster?
Do I "just" need to chisel the mantle and surround off the wall before stripping it, installing inset and the refitting mantle and surround.
Photograph at
http://i102.photobucket.com/albums/m101/jimbohkm/DSCF0023sml.jpg
I'm looking for the least messy route of removal, ever the optimist!
Thanks in advance
Photograph at
Thanks in advance
