Cubist
As rain has stopped play, hopefully only temporarily, I decided that now would be my best opportunity to provide an update on progress with the Infill Panel Caulking project I discussed in my introductory post. As a quick reminder; the First Lady and I are the bonkers stewards of 16th Century Oak Timber Frame cottage on the Shropshire / Herefordshire border which was fully restored - from the ground up - about thirty years ago. Since then the new timbers that were introduced have naturally shrunk and gaps of up to 10mm have opened up in may places. Previous owners, I'm sure based on best advice available at the time, tried to remedy this problem using silicon sealants and other now inappropriate materials. When this remedial work was done the timber shrinkage process was not complete and consequently these materials have either parted company with the timber frame and/or the infill panels - fortunately.
In my first post I was looking for some guidance concerning my thoughts on the most effective strategy to correct this problem, and in light of the fact that during the restoration of the building a portland cement based render had been used for the infill panels. I will not bore you by recounting the options I was weighing at the time, and the valuable advice received from contributors to this forum, except to say that my chosen strategy was to remove the inappropriate silicon sealants, where necessary open an air gap between the cement render and the frame, pack the resulting cavity with Oakum and/or Caulking Cotton - thus isolating the cement render from the timber - but leaving a cavity of 15-20mm deep that could then be filled with Lime Putty to close the gaps permanently.
That was a couple of weeks back now and after a few false starts, owing to failures to get the desired finish with the lime putty and the need to experiment with different grades of sand and ratios of putty to sand to produce a suitable and effective final filler I now feel that I making some serious headway. That said however, with all the other not to be neglected tasks around here, I suspect that much of the summer and early autumn will be needed to finish the job - hopefully.
On balance I am very pleased with the results and frankly I am very impressed with the versatility and performance of Lime in all its forms - though why that should be new to me given my lifelong admiration of the Pantheon I know not. True, it can be difficult to work with but seemingly it is also quite forgiving provided you get the mix ratios right. Given the weather over the last weeks and the fact that I've been forcing the lime plaster into crevices some minor cracks did appear but diligent misting and brushing overcame most of these. Inevitably there a few spots where I had to root out some of the plaster and refill to get a structurally sound finish but the lime whitewash I was using, applied sparingly and frequently, filled any remaining minor fissures.
During the course of the work so far I have been pleasantly surprised by some unexpected events and circumstances. Initially I was informed by one Lime products supplier that Lime mortars would not bond with cement based renders this does not appear to be true. Good, clean and sound bonds appear to have been achieved in most of my efforts but that may be due to the fact that I am forcing the material into relatively small but deep crevices between the original mortar render and the timber frame.
In addition I have found little evidence of damage to the timbers owing to the use of non-breathable products - probably due to the failed silicon treatments allowing air to circulate and perhaps aided by the near 50cm thatch overhang helping to keep rain water off the walls. So far, so good but I suspect I'll be having some unhappy moments as I progress around the remaining 80 infill panels.
I am still struggling to get photographs embedded in these posts but will continue trying as requested by some in reply to my earlier post. I have also decided that this forum would be a good place to record some of the past and future repairs and enhancements we have made to the house - hence the subject header 'Fircoft Chronicles'.
I'll keep you posted and will shout for help, commiseration, et all as circumstance dictates.
Cheers,
Cubist
Cheers,
Cubist
