Sorry for the barrage of questions, but I'm a bit stuck...
What is the best finish for daub panels that are not covered in lime? I am experimenting with lime wash, but the results are not great as the staw in the daub is over visible.
Many of the original infill panels in the house have a ~2mm coating/covering over the daub - would this be lime plaster or distemper? These look much better and I'd like to recreate this - any thoughts?
If you think its lime Can you 'skim' lime plaster on to daub, if it does not have the 'finger' holes in the surface to key the plaster?
If distemper - how should I prepare the surface? And do I limewash over this?
Finally - would the answers to the above be any different for a bathroom, given steam etc?
