Not a reference to Plank-Herschel, but an attempt to get a bathroom with some ventilation.
We have one of those 17th century houses with a whacking great chimney in the middle (or rather, with a lot of missing space in the middle, at least some of which must be a chimney). Our bathroom is currently internal (no windows), and the ventilation is poor. We'd ideally like a window in it, but thought this might be a pipe dream. However, an architect suggested that it was possible that there was quite a bit of missing space beside the bathroom, which might perhaps join up with a gigantic "cupboard" with an exterior wall which the COs might allow a little window in.
Before I go ahead and instruct the architects, I'd like to try to work out if the missing space does exist that would allow the bathroom to connect to the cupboard. I've been wandering around with a tape measure, and have enlarged a small hole in the lath and plaster of the cupboard to look through to see what I can see on the other side (seemed to be a beam).
What's the best way to do this kind of complicated house plan and to work out where the lost space is / if there is any? I need to work out not only the floor plan, but also the probable heights of the ceiling at all points, to allow for the eaves dropping down. Is detailed tape measuring the answer? Are there any tricks of the trade that I should know? The house isn't a succession of straight lines, so it's quite difficult to plan.
Is there a more scientific way to work out the actual size of the chimney than banging? On the ground floor, the chimney (which did have two fireplaces back to back, I believe) has been blocked up on both sides, so I can't tell how much really is chimney. The amount of 'missing space' is equivalent to a good sized bedroom in a modern house!
