simonjamesm1
Hi,
We've had the wiring replaced in our 1800 (ish) red brick house. The walls are lime plastered and we chased through the lime into the brick, which was actually very neatly done apart from one chase where the bricks seems to break up (poor set of bricks). Has anyone had any experience of filling them in? I have had some advice saying just use 3 part cement, lime, sand mix, others say use a bonding agent to create a bond onto the wires then fill or use a filler then lime plaster over.
I am told that lime on its own will struggle to bond to the cables. The circuit protected by a 30mA RCD so there is no cable conduit, which I imagine would be even harder to get lime to bond to.
Any tips or advice would be great!
thanks
thanks
