Hi all,
Story is that chimney is being rebuilt at the moment by a stonemason. The stone is thin in places, around where the flue passes along the gable wall. A proposal has been made to:
1. Drop liners down the flues for the lower two fireplaces, needed for one which is going to be used, just in case wanted in the future for the other (I'm working on the premise that I won't want fires upstairs) and these are already closed off.
2. Seal off at top of fireplace builders opening
3. Pour a mixture of X (lime mortar/vermiculate or leca etc?) into the stack from the top which will set and bind everything together.
There are plenty of examples on the web of loose fill being poured into flues around liners for insulation reasons, but not so much about doing it with a wet mix for structural reasons, which is why I am asking if anyone has any experience of this? Just trying to evaluate the pro's and con's.
Secondly, if is a good idea in principle then what should the mix be? As an old building I am presuming that a breathable/flexible lime mortar mix would be better than pure cement. I also understand that perlite, vermiculite and leca are commonly used, from what I have read leca is standing out as the better option, and is used with lime mortar to make limecrete for floors, but I haven't seen anything about limecrete being used in chimneys.
Has anyone had any experience of filling a chimney flue in this way?
Regards,
Kenny.
Regards,
Kenny.
