Our 1912 front room floor is pine, T&G boards about 5" wide.
The room faces south catching full sun for several hours a day, and the wood has the appearance to me of being very dry - although the gaps between the boards are still quite small (most less than 3mm).
Instinct tells me that it would benefit from some 'feeding' - it would certainly get this if I used an oil + wax finish.
But reading various other threads, using a water-based finish will be easier to apply, more durable and require less maintenance.
So advice please as to:
1) Is there any benefit in replacing moisture / oil in the timber?
2) If so, will a sanding sealer + water-based finish do this, or does it simply form a barrier in the outer surface of the wood?
3) Is there much difference in the amount of UV protection given by oil/wax vs water-based finishes? We've not decided yet how much will be covered by carpet or rugs, so don't want different coloured patches if we move things around in future years.
Further info, if it helps with any anwsers:
Like many floors of the period it still has dark stain around the edges which needs cleaning off (I'll follow Toby Newall's suggestions for that), and I'm hoping to avoid anything more than a light sanding as it is reasonably flat still. I'm not intending to stain it.
Thanks in advance,
Andy
Thanks in advance,
Andy
