My house is stone built, circa 1860, with the back of the house built into a hillside up to the ceiling height of the ground floor. Originally weavers dwellings, houses, the terrace was "renovated" in the 60's to make 15 terraced houses, at which point a brick cavity wall was constructed in the downstairs on the gable and back walls, where the house is under ground. I am experiencing damp along the back and gable walls (to the fireplace), especially in that corner and removed the peeling, salty paper a few months ago, though the wall itself doesnt feel damp to touch, just salty. I intend to address this problem this year (maybe!) and will try and get a look in the cavity space first of all to see if there is any debris which could be causing bridging of moisture from the stone outside wall. If that isn't the issue, I wondered if it's possible that that the black rubbery looking physical damp proof membrane between the bricks in the cavity wall below ground level has decayed and failed? How long would such a dpc last, given that the house was renovated 50 years ago? And if it has failed, how difficult would it be to reinsert a physical dpc? I also have issues with the stone party wall between me and my neighbour, which I don't think has a cavity, but that's a different matter as I think it's penetrating from outside as it's quite high up the wall, but still below ground level if you know what I mean. To complicate matters our house is immediately adjacent to a road that runs along the back of the property, and public steps down the gable end!
