A
Anonymous
Guest
We are converting a church into a residential property.It is not listed.We have an extremely high window and have been told by the local authority that it needs rapid ventilation.Also we need to open it from the ground floor as the window is in a full height atrium position.A mechanism of a handle has been applied this is no use as it is pulling away from the wall.Can you suggest an alternative,electric or otherwise .
