We're just about to start renovating a 1910 detached brick house. Three walls (sides and back) are all rendered with cement render that has failed and needs to be removed, and I'm looking into options for insulating the house whilst we've got it all in pieces - whilst trying to keep costs down. There is a lot of penetrating damp in the walls which I'm keen to keep breathing, so we're looking for a more traditional/natural solution. Either we insulate the internal walls with something like Warmshell (which could cause problems as it would mean taking off all the plaster which has picture rails, skirting boards etc, and the window edges are not very deep), or insulate externally whilst we render. External insulation seems like a better idea in theory as its less disruptive, but if we do, we have two problems. Firstly, the front of the house is brick and we don't want to cover this up so I'm concerned about whether this will create thermal bridging problems if we don't insulate this section. Secondly we also have the issue of how a thicker render to the side walls looks where it meets the brick walls to the front - will it stick out really far and look strange?
So I'm looking for two pieces of advice please. Firstly, can anyone recommend which external insulation system is good (I've looked at warmshell and ecoCork so far. I like the idea of ecoCork as its thinner but I can see that the insulating properties aren't as good).
Secondly, does anyone know about the thermal bridging issue on the front wall? Would it not really be worth bothering if we don't do anything with this wall? Its north facing and not particularly exposed.
