billybuntus
I'm sorry before I start. I'm sure its been covered a hundred times.
The rear of our house is stepped. The ground floor is stone and at some point a single skin (brick) 1st floor has been plonked on the top (all rendered).
We have a permanent damp ground floor wall where I believe all the water from the first floor hits the sloped step and drives into the stone (even though its rendered). I'll not be taking off the render and leaving it bare to breath as the brickwork and stone'work' is awful.
The difference is probably around 60mm
I'm looking at some stage in the future to build out the 1st floor by insulating then over boarding (if needed?) the whole rear of the house and rendering.
I understand the concept of the insulation boards (either green wood variety or kingspan) but how do I fix them to the building. Do I need to provide ventilation etc? I'm sure I'll be greeted with hate email but it will be a concrete based render (probably webber monocouche to match the gable).
The roof above is flat so perfect to build out from and I only have one gable (the other side will meet a parapet wall).
Any advice will be gratefully received.
