steanywhere
Hi this is the my first time posting so I hope I'm providing all the information properly (and yes I've taken photos...!)
We moved into a late Victorian terrace house with some damp problems and I've been doing some digging....
From what I can tell the rear addition is built with quite shallow foundations and over the years the external ground level has been raised with more and more concrete and rubble. This has meant the external ground level is now at least as high as the internal floor level. Added to this the rear bay gutter drains directly into the corner of the rear addition (and guess what that is where the most damp is....!)
I've discovered two things after digging out the pseudo-French drain that had helpfully been filled with soil and pea shingle and thus keeping a lot of water directly next to the solid wall.
1. The old air vents aren't blocked from the outside but I'm guessing could very well be from the inside.
2. If you look below where the render has fallen off under the air vent there seems to be a slate DPC two rows of bricks up from the brick foundations.
Also there is what may well be an original drain - and thus possibly an original ground level?? - about 15cm from the top of the concrete path down.
This would have made the original ground level about one row of bricks above the foundations and one row below the DPC.
Another view of that shows also that the concrete hasn't been cut away from the wall next to the drains and goes right up to the kitchen door (ground and internal level the same) and again unsurprisingly this is the second most damp area internally....
So some questions....
1. Should I break up the concrete and reduce the ground level? If so to what level above the foundations?
2. The drains are running down the side return would it be good to get a drain survey done to establish that they are working properly?
3. If I do reduce the ground level what should I replace the concrete with?
4. Anything from the pictures that I've not picked up on please feel free to let me know...
Thanks in advance for your help....
