Hi all,
I really need some quick advise as my insurers are pressuring me for a reply and they have started hacking off so need to make a decision...Hate those!
My House is a small welsh farmhouse built around 1860 using local stone which is a hard volcanic stone and totally impervious to water. The property was pebbledashed in around 1980. The House is at 1000 feet overlooking the Irish sea and recieves high rainfall and very strong winds with regularity! A Year ago storms damaged the chimneys and has led to water ingress on both gable ends, the cement pebbledash is in very poor condition.After a year of battling insurers they have now decided correctly to remove the render. The stonework underneath is mixed rubble and large stones with lime mortar pointing.
I have two options. Either I can re render the gable walls in a flat cement render and paint or I can have the walls pointed up.
My feeling is to return the property to a more traditional finish. I also have no idea if the property was originally pointed or rendered.
Problem-
If I point in lime my concern is that it will not stand up to the prevailing weather conditions here. I also feel that cement would look awful as a pointing. I have defintely decided that the west facing gable will be cement rendered as it is so exposed As a matter of interest my North facing wall has been hacked off and left unpointed for 2 years now with no ingress of water moisture readings on this wall internally show it to be very dry.
The [problem I have is what to do with the East facing gable. This is more sheltered but gets less air circulation and sun than elsewhere so tends to take longer to dry after rain. Winters here can be very hard last year we had 8 weeks of rain and wind every day. Do you feel Lime would be suitable in these conditions? If so what mix? Non Hydraulic or NHL Mix? I also Have to do this work now as in the next few weeks so not ideal weather wise. Or would I be better just accepting that the weather here is so awful that cement render is the only thing to be recommended. The Interior of the house has been re plastered using lime plaster this was done last year, I do not know if this would affect the choice for the exterior.
Any advice would be most welcome.
Many Thanks
Hiri
Problem-
Many Thanks
Hiri
